Новата криза во Јемен
Re: Новата криза во Јемен
Се надминија овие овој пат како не бевме како овие ооо ни нато ниту никој немаше да се осмели
https://www.youtube.com/watch?v=4URdbk023Yw" onclick="window.open(this.href);return false;
Oнаа ми изгледа како југословенска хаубица од 105 мм што е ставено на тојота
http://www.youtube.com/watch?v=2y6JTltg09M" onclick="window.open(this.href);return false;
Ne e toa haubica, verovatno ZIS 3 bi rekol, mala e i granatata za 105 mm.
Interesni raboti na klipov, ja zapalija onaa tojotana so se PA topovite ama i municijata na nego ne se tacni. Ponatamu kako rasfrla ona gatlingot ja mislam deka ni ednas ne ja pogodija zgradana so ja gagjaa, totalno bespolezno trosenje na municija.
I na kraj outfitov. Dzivra, dres, sako, sandala. Ebati narodot, kakvi likovi.
PS ona pistolot so go mafta ovoj busaviov Marselo do crnjata (ne znaev oti i takvi huti ima) TT ec e ili colt , nekako na vtorovo mi vlece?
76mm ЗиС-3 е дефинитивно на техникалот. А Марсело мафта со ТТ.
https://www.reddit.com/r/YemeniCrisis/c ... _promises/" onclick="window.open(this.href);return false;
http://www.youtube.com/watch?v=XrwK-zS2HZ8" onclick="window.open(this.href);return false;
Kozojebna stoka...
https://www.middleeastmonitor.com/20180 ... -in-yemen/" onclick="window.open(this.href);return false;
Padnal nov Saudijski "Tornado"...
https://defence-blog.com/aviation/torna ... rabia.html" onclick="window.open(this.href);return false;
I jak komentar podole:The Panavia Tornado multirole combat aircraft of the Royal Saudi Air Force crashed at 04:41 AM local time in Asir Province on 12 July.
According to Arab Coalition spokesman Col. Turki Al-Maliki, a Saudi Arabian Royal Air Force Tornado jet came down in Asir region.
“The aircraft was returning from a training mission when it crashed in the southern region due to a technical failure.” said Al-Maliki.
Assir is on the Yemeni border, so presumably, the aircraft was felled by the type of technical malfunction that occurs when it is struck by a surface-to-air missile.
Ako vi se chitka za genezata na Huti-tskoto dvizhenje vo Jemen:
https://southfront.org/the-houthis-and-war-in-yemen-2/" onclick="window.open(this.href);return false;
Mh, mh, mh...
- gocka_990
Nesto se kuva druze iko ?Iko wrote:Mh, mh, mh...
Hutive zapochnaa nova golema ofanziva vo centralen Jemen, vo provincijata Marib - ovojpat "zadgrb" na Jemenskite pro-Saudiski "Hadi"-tski sili...sinojkja im go probija frontot i go zavzedoa centralniot planinski masiv Al-Zagan, bivshiot aerodrom kaj Sirva koj se naogjashe na negoviot vrv i koj behe od neodamna koristen za dopremanje na municija na koalicionite Zalivski sili vo Jemen - i zgora, na istite im nanesoa teshki zagubi vrz nivnite oklopni i mehanizirani sili - unishtuvajkji pogolem broj na tenkovi, borbeno-oklopni vozila i oklopni transporteri...udarot e neochekuvan i "Hadi"-te imale teshki zagubi...del od Kolumbijskite platenici koi se borat vo ovoj region na Jemen protiv "Huti"-te - sinojkja samite priznaa deka dosega se borele vo povekje vojni - no ne videle nekoj taka majstorski da smestuva stapici vrz oklopni sili i da taka umeshno vrz niv deluva so PO raketni lanseri, PT mini i improvizirani eksplozivni napravi kraj patot - kako shto toa go pravat "Huti"-te...
https://twitter.com/YemeniObserv/status ... 0891277312" onclick="window.open(this.href);return false;
https://twitter.com/YemeniObserv/status ... 5499626496" onclick="window.open(this.href);return false;
Na posledniov tvit idete nadolu redosledno i kje gledate mnoshtvo pogodoci:
https://twitter.com/YemeniObserv/status ... 5830881281" onclick="window.open(this.href);return false;
Nedaj Bozhe namesto bednive, smeshnive i patetichni UCK-i so koi si imavme rabota (a toa shto ni niv ne uspeavme da gi someleme dovolno govori kakvi papaci sme od drzhava i nacija) - da 2001-va si imavme rabota so vaka sposobna, ulavo hrabra i krajno reshitelna gerila ko "Huti"-ve...kaj kje ni beshe tek togash krajot...
тие т-55 ги напуштиле овие од јужна сириска армија ги некаде на кај 40 минута кај што ги запалија овие хутите
http://www.youtube.com/watch?v=V-d4h_j-8mk" onclick="window.open(this.href);return false;
еве нешто и од саудиците
http://www.youtube.com/watch?v=fxETV5uQ2_8" onclick="window.open(this.href);return false;
еве за онаа што беше кажано за колумбиците
http://www.youtube.com/watch?v=gdj-Ud5Z4Ck" onclick="window.open(this.href);return false;
Pa najiskreno drag moj Kocho - neshto bash uopshte i ne gi zhalam...najobichni "kuchinja na vojnata"...smrdeni platenici koi majka rodena za pari kje prodadat...koj shto si seel - toa neka si zhnee...
Koлумбија е далеку од јемен сега тое то кој за шо учел и за то ке гини
еве видео од едно село во јемен од хутитеи и подолу другото видео од војската подржана од саудиците вторите се фалат дека ослободиле нешто а подоцна да бидат истолчени
http://www.youtube.com/watch?v=sAmI0KQncck" onclick="window.open(this.href);return false;
http://www.youtube.com/watch?v=8mHKq2l6tS8" onclick="window.open(this.href);return false;
"Huti"-te - deneska i oficijalno pobaraa od Ruskata Federacija da se vkluchi diplomatski vo reshavanje na Jemenskiov kurshluz...seushte se cheka odgovor od Ruskoto MNR...
Vodachot na "Huti"-tskoto dvizhenje - Mahdi Al-Mashat - deneska najavi deka slichno baranje kje se isprati i do Kinezite i Francuzite...
"Huti"-ve gi spukaa so vooruzheni dronovi - glavnata rafinerija na ARAMCO (Saudiskata Drzhavna Naftena Kompanija) vo blizina na Saudiskiot glaven grad Rijad - i megjunarodniot aerodrom vo Abu-Dabi vo Obedinetite Arapski Emirati...i pokraj najsovremenite radarski sistemi - obete PVO (Saudiskata i Emiratskata) - ne uspeale da gi detektiraat nitu soborat...prichineta e vo obata sluchaja relativno mala shteta - no simptomatichen e porastot na "Huti"-tskata tehnoloshka mokj za izveduvanje na vakvi napadi...se raboti navodno za vooruzheniot dron od tipot "Samad-3" - koj veruvale ili ne - e domashen "Huti"-tski produkt, napraven vo podzemnite peshteri vo Jemen - i na koj rabotele navodno par mashinski inzhenjeri koi bile porano oficeri vo Jemenskata Armija - a sega se chlenovi na "Huti"-tskata gerila...
Ako ova poslednovo se ispostavi kako vistina - onda kapa dole...da sozdadesh dron vo peshtera koj precizno vooruzheno kje dejstvuva vrz celi oddalecheni vo prviot sluchaj okolu 1 100-tina km, a vo vtoriot sluchaj bezmalku 1 500-tini km - znachi navistina da imash impovizirachki dar i da si odlichen inzhenjer...
Pantzir S2 ili SMIko wrote:"Huti"-ve gi spukaa so vooruzheni dronovi - glavnata rafinerija na ARAMCO (Saudiskata Drzhavna Naftena Kompanija) vo blizina na Saudiskiot glaven grad Rijad - i megjunarodniot aerodrom vo Abu-Dabi vo Obedinetite Arapski Emirati...i pokraj najsovremenite radarski sistemi - obete PVO (Saudiskata i Emiratskata) - ne uspeale da gi detektiraat nitu soborat...prichineta e vo obata sluchaja relativno mala shteta - no simptomatichen e porastot na "Huti"-tskata tehnoloshka mokj za izveduvanje na vakvi napadi...se raboti navodno za vooruzheniot dron od tipot "Samad-3" - koj veruvale ili ne - e domashen "Huti"-tski produkt, napraven vo podzemnite peshteri vo Jemen - i na koj rabotele navodno par mashinski inzhenjeri koi bile porano oficeri vo Jemenskata Armija - a sega se chlenovi na "Huti"-tskata gerila...
mu e majkata
nekoj probuva da gi iznenadi rusite te so roj te so poedinecni obidi.
Users browsing this forum: Bing [Bot], rascia82 and 18 guests
