Белл 412
Re: Белл 412
Ova e interesna stvar..imam i so Mi-24 vakvi gledano videa.
Kolku kosta edno vakvo?
- Христијан
Re: Белл 412
Стварно што пари е играчкава?
Re: Белл 412
Сабајле од тераса го пушташ до продавница,продавачот закачува најлоните и лебот дома за 1 мин!IgorMKD wrote:Стварно што пари е играчкава?
Re: Белл 412
BELL 412 COMPLETE FUSELAGE ASSEMBLY KIT incl. mechanics, ZG 26 $7,288.12 ..... Ситно
Description of kit content:
- all fuselage parts, glass fibre, with white coating
- fuselage centre part, tail boom, fuselage nose
- front and rear engine lid
- two sliding doors, two front doors, fuselage end cap
- plywood former set
- 4 windows, vacuum formed, further glass material already marked for cut offs
- all door hinges, aluminium door handles for functional opening of the front and rear doors
- Fibre glass sliding door guide rails
- Fibre glass horizontal stabiliser, ready assembled
- entire fuel tank system
- ventilation system cover grids and fasteners
- ready assembled aluminium skid landing gear, with roving inlets for high load rating
- mechanics fitting set for the SSM mechanics
- all steering push rods in accurate length 2,5mm diameter, both sides threaded, ball linkages and fasteners
- mechanic assembly kit
- ZG 26 engine with pull starter
- flex drive unit
- main rotor assembly kit
- tail rotor assembly kit
- main and tail rotor blades
- exhaust system
- detailed assembly instruction for fuselage.
If you comply with all our instructions regarding the assembly of the model and the adjustment measures, your helicopter will show perfect flying characteristics from the very first beginning.
Standard delivery time: 5 weeks
Dimensions:
Fuselage length: 1640 mm
Fuselage width: 320 mm
Rotao diameter: 1800 mm
Fuselage hight incl. rotor head 520 mm
- flex drive unit
- exhaust system
Dimensions:
- Христијан
Re: Белл 412
AlexGreat wrote:Сабајле од тераса го пушташ до продавница,продавачот закачува најлоните и лебот дома за 1 мин!IgorMKD wrote:Стварно што пари е играчкава?
хахахахаха ни да се мачиш ни ништо.
The only easy day, was yesterday!
Re: Белл 412
Boga mi..za 7000 USD ke odam sekoj den do prodavnica bos!
Re: Белл 412
Скапичко... Не за друго, кога ќе ја поткачам некаде има да ја собирам со метла и лопатче... За тие пари пре би купил некоја добра фото опрема што уствари одамна се острам...
Re: Белл 412
Ja bi dodal ushte tolku i bi zel nekoe novo malo no dobro koliche....
- zdravkin2000
Re: Белл 412
za tie pari PPL dozvola ke zemes jest da igrackata e dobra ali brate PPl dozvolata e pojaka
Re: Белл 412
за 15.000 еур има супер колички БМВ 520д 2004год е отприлика толку. или на ново, голфче,Астра Гтц а не ова, хеликоптерче... со 7500еур ке си купам мотор, 600ка... и пак за минутка ке стигнам до продавница и назадIko wrote:Ja bi dodal ushte tolku i bi zel nekoe novo malo no dobro koliche....
Господ простува и на терористи... А наша задача е да им организираме средба со него. ЕСЗ-ТИГАР
- Дарко Д
Re: Белл 412
Toj sto si e po helikopteri ne se otkazuva od nego po nikoja cena
[img]http://www.danasoft.com/sig/goko.jpg[/img]
Re: Белл 412
Доколку си голем фанатик на овој модел ... 412ка и ако си во можност,АКО СИ значи,тогаш нема двојба..секако дека би го купил некој.
Тој што има пари за вакво,има и за моторче и за кола заедно.
Users browsing this forum: No registered users and 5 guests
