Flight simulator, Lock on и останати симулации. Flight simulator, Lock on and other flying simulators.
Posts: 35661 Joined: 04 Aug 2006, 14:01
Post
by dragan_mig31 » 31 Aug 2006, 18:53
sea vidov na bugarskiov forum deka imalo ATC za lock on??????
prv pat slusam ova sea.eve fotki.
Posts: 373 Joined: 04 Aug 2006, 19:09
Post
by fly_macedonia » 01 Sep 2006, 01:07
Post
by dragan_mig31 » 01 Sep 2006, 02:43
fo takvi scenarija se praktikuva RADIO SILENCE i nikoj ne smee da zucne posto moze na tj nacin da se otkrie pozicija ili namera.
Posts: 2476 Joined: 18 Jul 2006, 13:23
Post
by avijacijamk » 01 Sep 2006, 05:33
хахаха, fly_macedonia овие нејќат да те дружат, хахаха
Posts: 1256 Joined: 04 Aug 2006, 22:48
Post
by Loaded_Dice » 01 Sep 2006, 14:53
Jas mislam deka bi bilo super. Ke moze da obavestuva za pozicijata na neprijatelskite avioni i da ne vektorira po potreba ( Samo da ne se koristi ruska doktrina
) taka da bi mozelo da bide dosta interesno koga se leta full realism.
Post
by dragan_mig31 » 01 Sep 2006, 20:18
abe i ja sum za ali ja nema sansa da letam po ruska taktika naveduvanje od ground radar!!!!
Post
by dragan_mig31 » 02 Sep 2006, 14:57
fly macedonia aj najdi go oova pa da go probame denovive?ako sakas?da vidime sto e!
Post
by fly_macedonia » 02 Sep 2006, 16:08
Најдов верзија 1.0
Еве screenshot
Post
by Loaded_Dice » 04 Sep 2006, 21:28
Pa kako ke probame be, koga ti teknuva nemoze, slab mu e kopjuterot. Ako moze nekako da se proba ke bide super ama se mislam deka treba da ima i Lock On instalirano
