Based on experiences of the 1981 Syrian War, constant relocation of all assets was key to survival of Dani's unit, the 3rd missile detachment of the 250th Serbian Air Defence Battalion. Although the SA-3 / "S-125M Neva" system is not a mobile SAM complex per design, its solid fueled missiles are transportable in near combat ready condition (in fact the Polish military created a mobile SA-3 version on T-72 tank chassis in the 1990s).
Therefore Lt. Col. Dani trained his SA-3 unit to achieve a 90 minute equipment break-down time with minimal lighting provided for better camouflage, one hour better than the standard time. Further set-up and break-down time reductions were achieved by reducing the SA-3 unit's number of active 5P73 launchers and V-601P missiles to just 2x2 from the original 4x4 configuration.
This reduction in missile capability was justified, because of the expected strictly limited time slots and occasions where a Serbian SAM battery could open fire in face of a tremendous NATO Wild Weasel capability, with any hope of self-preservation. The lean use of SAM missiles also became a necessity later on, as the initial March 24, 1999, 20:20 NATO air strike destroyed 100pcs of ready to use V-601P spare missiles in two concrete vaults at the Jakovo SAM base.
Lt. Col. Dani made it a strict field rule that the SA-3's UNV type fire control radar could only be turned on for a maximum of 2 x 20 seconds in combat, after which the battery's equipment must be immediately broken down and trucked to a pre-prepared alternative launch site, whether or not any missile has been fired. This rule proved essential, because other Serbian AAA units, emitting high-frequency radiation for any longer periods or forgetting to relocate, were hit by AGM-88 HARM missile counter-strikes from NATO aircraft, suffering radar equipment and personnel losses.
In order to train personnel operate efficiently under such pressures, Zoltán Dani obtained access to an "Accord" electronic signal simulator, which allowed the SA-3 radar and guidance crew practice combat scenarios based on imitated engagements. Several soldiers were removed from position both during the pre-war practice drills and wartime guard shifts, when they proved unable to cope with the psychological stress of being targeted by enemy aircraft.
It was decided two missiles would be launched against any target near simultaneously, in order to maximize hit probability. Unusually, launches were to be conducted against NATO aircraft that had already accomplished their ground strike missions and were about to leave Serbian airspace. Their northern heading was pointing away from the direction of powerful NATO airborne jammer sources, thereby allowing the SA-3's un-modernized UNV fire control radar set to operate with less interference.
Dani's mobility rule was strictly observed in his unit, with the trucks travelling more than 100.000 km during the 78 days of Kosovo War, as they constantly shuttled missiles, radars and equipment between the dozen alternative launch sites, most of them embankments left over from already phased out SA-2 (S-75) units.
Radar sets obtained from confiscated Iraqi MiG-21 planes were planted around the SAM sites to serve as active emitter decoys, which diverted some anti-radiation missiles from the actual targets (dozens of Iraqi MiG-21/23 warplanes, sent to Yugoslavia for industrial overhaul, were seized in 1991, after Saddam Hussein's invasion of Kuwait.) Retired SAM radar sets were used as optical decoys, left at well-known military bases to lure NATO planes waste munition on worthless targets. Owing to these measures, Dani's unit evaded 23 incoming HARM missiles, all of which impacted off-site with insignificant or zero damages.
General surveillance of NATO aircraft was provided by vintage P-18 radar sets, which used vacuum tubes and a large rotating Yagi antenna grid for meter-band illumination. Under optimal conditions the soviet-made P-18 was able to plot large-Radar cross-section aircraft from 125 to 200 km, depending on the target's size, but with a high range inaccuracy of several hundred meters.
Zoltán Dani tuned his P-18 to the lowest possible frequency and further replaced four major capacitors in the electronics to achieve an even longer wavelength, hoping that meter band waves would reflect from the inside of targets, rendering stealth aircraft skin technology ineffective. In practice his modified P-18 provided stable plot of F-117 movements from just 25 km, which was useful when combined with the comparatively short missile range of the SA-3 air defence complex. Furthermore, the P-18 meter band radar could be kept almost constantly emitting, since most NATO radar warning receiver devices did not cover such a very low frequency band.
DCS: A-10C Warthog
- apo_bullseye
Re: DCS: A-10C Warthog
@filipv
цел систем ВОЈИН има работено за време на цело бомбародвање.Војин е комплексна стурктура од поише делови на ПВО и радари за набљудување склопени како една целина така да во било кое време е можен преглед на ваздушен простор над југославија и пошироко.
