The A350 XWB (Xtra Wide-Body)
For our english speaking users.
Postby Airbus » 21 Dec 2007, 19:07
The worlds most advanced medium capacity long range airliner
The A350 XWB (Xtra Wide-Body) is Airbus’ response to market demand for a medium capacity long range wide-body family. Designed with airlines’ priorities in mind, the A350 XWB confronts the challenges of high fuel prices, rising passenger expectations and increasing environmental concerns.
Available from 2013, it has an entirely new, uncompromised, 21st Century design with a wider and taller fuselage for extra space and passenger comfort. A complete family of airliners sized to generate cost reductions and provide unprecedented operating flexibility for airlines; three basic passenger versions are being offered. With a range of up to 8,300nm/15,380km they include the A350-800 for 270 passengers in a spacious three-class configuration; the A350-900 for 314 passengers and the A350-1000 seating 350 passengers. An ultra long-range version, the A350–900R, will fly even further while a freighter version, the A350–900F, will complement the passenger models.
As benefits the most advanced aircraft family in its segment, the A350 XWB is able to provide greater economy on long-range markets and is equally attractive as a route opener or as part of a multi-type Airbus fleet offering optimized network solutions. Thanks to the application of the latest innovations, the A350 XWB is able to offer 20 per cent lower cash operating costs per seat than competing aircraft in this size category and fuel efficiency improvements of up to 25 per cent per seat.
The fly-by-wire A350 XWB Family is a significant addition to the Airbus product range. A member of the Airbus FBW Family of aircraft, it benefits from the same operational commonality as the other members of the Family. This handling and flight deck commonality allows airlines to benefit from the unique Airbus Family concept of cross crew qualification and mixed fleet flying, and will ensure smooth introduction into service.
A350-800
AIRCRAFT DIMENSIONS
metric imperial
Overall length 60.6 m. 198 ft.9 in.
Height (to top of horizontal tail) 16.9 m. 55 ft. 4 in.
Fuselage diameter 5.96 m. (horiz) 19 ft. 58 in. (horiz)
Maximum cabin width
Cabin length
Wingspan (geometric) 64 m. 210 ft.
Wing area (reference) 443 m2 4,740 ft2
Wing sweep (25% chord) 35 degrees 35 degrees
Wheelbase
Wheel track
BASIC OPERATING DATA
metric imperial
Engines 2 Trent XWB 2 Trent XWB
Engine thrust range 333 kN 75,000 lb. slst.
Typical passenger seating 270 (3-class) 270 (3-class)
Range (w/max. passengers) 15,400 km. 8,300 nm.
Max. operating Mach number (Mmo) 0.89 Mo. 0.89 Mo.
Bulk hold volume - Standard/option
DESIGN WEIGHTS
metric imperial
Maximum ramp weight
Maximum takeoff weight 245.0 tonnes 540.1 lbs. x 1000
Maximum landing weight 182.5 tonnes 402.3 lbs. x 1000
Maximum zero fuel weight
Maximum fuel capacity 150,000 Litres 39,630 US gal.
Maximum structural payload
Typical volumetric payload
Postby Airbus » 21 Dec 2007, 19:09
A350-900
AIRCRAFT DIMENSIONS
metric imperial
Overall length 66.9 m. 219 ft. 7 in.
Maximum cabin width
Cabin length
Wheelbase
Wheel track
metric imperial
Engine thrust range 387 kN 87,000 lb. slst.
Typical passenger seating 314 (3-class) 314 (3-class)
Range (w/max. passengers) 15,000 km. 8,100 nm.
DESIGN WEIGHTS
metric imperial
Maximum ramp weight
Maximum takeoff weight 265 tonnes 584.2 lbs. x 1000
Maximum landing weight 202.5 tonnes 446.4 lbs. x 1000
A350-1000
AIRCRAFT DIMENSIONS
metric imperial
Overall length 73.9 m. 242 ft. 6 in.
Maximum cabin width
Cabin length
Wheelbase
Wheel track
metric imperial
Engine thrust range 422 kN. 95,000 lb. slst.
Typical passenger seating 350 (3-class) 350 (3-class)
Range (w/max. passengers) 14,800 km. 8,000 nm.
DESIGN WEIGHTS
metric imperial
Maximum ramp weight
Maximum takeoff weight 295 tonnes 650.4 lbs. x 1000
Maximum landing weight 225.5 tonnes 497.1 lbs. x 1000
Re: The A350 XWB (Xtra Wide-Body)
Postby Skopjeair » 14 Jun 2013, 10:04
Полета!
Skopjeair
H.M. MURDOCK
H.M. MURDOCK
Postby IgorMKD » 14 Jun 2013, 17:54
Убав :bravo:
"Igor, dojde vreme skoloto da e posledna sansa za onie koi nemaat nikakov drug talent ;)".
Postby Bobo » 14 Jun 2013, 17:56
IgorMKD wrote:Убав :bravo:
DreamLiner Report to this post..
Postby Зоран » 14 Jun 2013, 18:36
Nice. :mrgreen:
Зоран
Mодератор
Mодератор
Postby alvarhanso » 14 Jun 2013, 20:33
Немаме тема за него во Цивилна?
The future is already here - it's just not evenly distributed
Postby karamba » 14 Jun 2013, 21:15
alvarhanso wrote:Немаме тема за него во Цивилна?
Изглеа нема, може треба една општа да се отвори горе стрикли Airbus, Boeing итн, чисто ко предлог, па и ова да иде таму...иначе екстра е машинава колкави се крилана со винглетине(така се викаа мислам) на крај нагоре упм, јес да се далеку еден од друг али напред кај шофершајбната дека е црн тој дел ме потсеќа на SSJ100 или па е обратно :)
Return to English speaking users
