Naval Air Warfare Center Weapons Division (NAWCWD) in China Lake, Calif., performed the first bio-fuel flight test in AV-8B Harrier #88 last week in the upper Mojave Desert, the Navy said Friday.
After preliminary ground test events last week, the Harrier was flown by Maj. Gary “Mouth” Shill, a pilot from Air Test and Evaluation Squadron (VX) 31 at NAWCWD. The Harrier rolled down the runway several hundred feet before a short take off, then accelerated into a maximum performance climb. Testing included phasing maneuvers, hard cranks, wind up turns, hard turns with nozzle biting and even some inverted flight, according to the Navy.
“We usually have small challenges in a test flight, but not on this one,” said Hal Bennett, project lead for the AV-8B bio fuel flight test program. “We hit all the points – collecting the numbers and rolling through the complete card deck in an hour. It was very successful.”
The last portion of the flight included performance hover maneuvers. The Harrier came in slow, about 100 feet off the ground, into a hover, said Bennett. “It hovered for about two minutes to establish some engine performance parameters – to see how powerful the engine was at a given temperature. Shill depressed the rudders and moved the ailerons to check and validate the pitch, roll, yaw and hover characteristics. This allowed him to monitor and evaluate what impacts the ‘bleed air’ usage had upon engine performance. Again, no anomalies noted,” he said.
The test concluded when the pilot conducted a vertical landing and idled the motor a short time to let it cool. Shill said the Harrier performed on the 50/50 blend as it does with standard JP8. “There were no anomalies that I detected that would prevent the Navy from using the biofuels blend for the AV-8B,” he said. “The instrumentation worked flawlessly,” Bennett said. “We conducted the test, captured the data and then debriefed. ... We usually have challenges during a test flight, but this whole thing went according to script.”
Navy Tests Bio-Fuel-Powered AV-8B Harrier
Users browsing this forum: No registered users and 13 guests
