Се запали B777 на Singapore Airlines
Факти, причини и последици од авионските несреќи.
Facts, reasons and outcomes from aircrash investigations.
Postby Марко СВ.Н. » 27 Jun 2016, 12:53
A Singapore Airlines Boeing 777-300, registration 9V-SWB performing flight SQ-368 from Singapore (Singapore) to Milan Malpensa (Italy) with 222 passengers and 19 crew, was enroute at FL300 over the Andaman Sea about 2 hours into the flight when the crew decided to descend the aircraft to FL170 and return to Singapore due to an oil leak at the right hand engine (GE90). The aircraft landed safely on Singapore's runway 20C about 2:20 hours later and slowed down. While passengers broke into clapping and cheering and the aircraft turned off the runway, a spark was seen at the right hand side causing the right hand engine and wing to catch fire, the aircraft stopped on the taxiway, emergency services sprung into action and extinguished the fire, the crew kept the passengers on board while firefighters doused the fire. The passengers subsequently disembarked via stairs. There were no injuries, the aircraft sustained substantial damage to right engine and right wing.
Марко СВ.Н.
Re: Се запали B777 на Singapore Airlines
Postby IgorMKD » 27 Jun 2016, 13:02
Добро што се вратиле на време, споменик треба на живо да им дигнат на пилотиве, херои! :bravo:
"Igor, dojde vreme skoloto da e posledna sansa za onie koi nemaat nikakov drug talent ;)".
Postby karamba » 27 Jun 2016, 13:11
Се чини дека во право време решиле и се вратиле, да мислеле малку повеќе ова ќе можело да биде голема трагедија, добро решение.
Return to Авионски несреќи / Case study
