Macedonia 2014 scenery project for FSX
samsamfin
Post by samsamfin »
Hello,
I'm working on my little scenery project for Macedonia. I'm using openstreetmap data for streets, railways, rivers and lakes. Land class tiles im adding on my own. I still have lots of work to do, like lake and river elevations and adding land class tiles for cities and towns and villages. No changes have or will be done to any airports.
Feel free to try it out: http://1drv.ms/1eoCZRP
Feedback is highly appreciated!
-Sami
Зоран
Mодератор
Mодератор
Re: Macedonia 2014 scenery project for FSX
Post by Зоран »
samsamfin wrote:Hello,
-Sami
SamI please write more about your Job.
From pictures I can understand a lot .
you Work on project of Vardar Valley.
samsamfin
Post by samsamfin »
I uploaded a map of the whole area i'm working on. so far all roads from OSM data have been added, as well as rivers, streams, lakes, railroads, and some of the land class. land class is the most time consuming portion of the project, since OSM data is pretty much useless for that purpose.
Зоран
Mодератор
Mодератор
Post by Зоран »
samsamfin wrote:I uploaded a map of the whole area i'm working on. so far all roads from OSM data have been added, as well as rivers, streams, lakes, railroads, and some of the land class. land class is the most time consuming portion of the project, since OSM data is pretty much useless for that purpose.
Pretty god until now,
Explain abbreviations we are not Geode-ts.
samsamfin
Post by samsamfin »
nothing to it really, OSM comes from OpenSteetMap :)
Зоран
Mодератор
Mодератор
Post by Зоран »
Фала ( thank you) :bravo:
Dante
Post by Dante »
Is there any chance to do a scenery of LWSK for FSX??
Project Officer at Clean Aviation JU
ENAC Graduate in Aeronautics and Space
Dante
Post by Dante »
checked it out, man you did a good work. SWEET!!! thank you very much!! VFR flights are awesome with this scenery :)
samsamfin
Post by samsamfin »
make sure you have the latest version (updated yesterday) :p i will look into this airport scenery, but i wont promise anything yet. im going to macedonia this summer, and ill see if i can somehow agree with the authorities so that i could snap some photos around the skopje airport. but thats a big maybe. Ivano Marongiu made skopje airport for FS9. i tried it with FSX - works so and so, trees are displaying black boxes around them, and frame rate drops a lot. maybe he could compile it for FSX.... who knows...
Dante
Post by Dante »
nice!!!! I know there is for FS9, he made it using google earth, there is a 3D sample of the airport. If I knew how to do that, I would have done it . :)
samsamfin
Post by samsamfin »
aaaaa if theres a SketchUp model for it, then it might be easier. ill look into it after easter:)
Марко СВ.Н.
Post by Марко СВ.Н. »
Can you make it for FS9 ? and can you tell me how to make photoreal scenery i'm interested to make photoreal scenery for my city.FS9 sure.
samsamfin
Post by samsamfin »
easiest way to make photoreal, is to use Maps2BGL by Gunnar Daehling. all you need to do, is to make kml of the area you want. open that kml file with Maps2BGL, click Download tiles, and after that click Create TGA+patch. just remember that photoreal area covers absolutely everything, you wont even have autogen buildings. you can use Maps2BGL without google earth kml file, but in that case you have to type the corner coordinates manually
samsamfin
Post by samsamfin »
Adding some objects for the scenery
Марко СВ.Н.
i can't open maps2bgl it's saying service not configured
OK i fixed it now thank you very much for your help :)
samsamfin
Post by samsamfin »
in the setup folder you will find maps.ini file. open it with notepad, and look at the "SERVICE=g*****.*** VERSION=&v=74". you need to replace that g*****.*** with google.com. now, last time i tried to download tiles from google, it was blocked, so if it doesntwork, you can try different map services. i know that Bing maps still works. give it a try
Марко СВ.Н.
i fixed it with google.com but the tiles is going -0 is that normal ?
Марко СВ.Н.
ok i finished with installing scenery but the area is now black why ?
samsamfin
Post by samsamfin »
if its black, it means google is blocking your download. try "SERVICE=virtualearth.net VERSION=.jpeg?g=52"
Dante
Post by Dante »
here is the sketchup for the airport https://3dwarehouse.sketchup.com/model. ... 3dbl&hl=en" onclick="window.open(this.href);return false;
